Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 05-02-2008, 07:20 PM
planekrazie's Avatar
planekrazie is on a distinguished road
Hobbycnc pro + relay for router start???
Hey guys,
I want to be able to control my router on or off by gcode through mach3 with the hobbycnc pro board. Is this possible? If so would someone kindly explain the process to me.
1) how to build it.
2) where to get parts.
3) how to hook it to the hobbycnc board and through the pc
Thanks a million
Steve
Old 06-29-2008, 08:13 AM
sawmiller is on a distinguished road
i dont have the hobbycnc pro board yet, so i dont know if they have them, but the pminmo breakout has limit switch connectors and 2 relay connections.
you just add a 5 volt controlled solid state relay, i used gordos m-0ac5ah
and i put it in the bottom of a outlet box , controling a outlet, with a plug pigtail to plug it in to a circut. be careful, never work it energized. and when initaily testing i would use a lamp pluged into the outlet and a switch to a 9 volt battery for the control voltage.. ( make sure the battery is slightly discharged. the relay has a control voltage of 0 - 8 volts)
but i would look on whatever documation you got and see if there is a relay connection.
i hope so, as if i switch to the hobbycnc pro, i will want one, if it doesnt have it i will have to alter it, the relay is just too handy.
dan
Router 0/1 with solid state relay bigz1 General Electronics Discussion 6 04-24-2008 08:37 PM
Correct Relay board for Mach and router WilliamD Mach Software (ArtSoft software) 3 04-16-2008 06:54 PM
HobbyCNC or Xylotex for router? woodguy DIY-CNC Router Table Machines 10 07-16-2007 05:24 PM
Will this relay work with my router? spoiledbrat General Electronics Discussion 1 06-11-2005 10:51 AM
Relay vs Router power ratings sol General Electronics Discussion 5 06-23-2004 09:17 PM
