I just finished putting together the power supply, setting up the Pro board, and connecting the stepper motors. The problem I am having is that only the X axis moves when being jogged and then it only moves counter clockwise. The Y and Z steppers won't do anything. When I turn on the PS I can feel a thump in each Stepper Motor which I take it as locking up. The Y axis when moving is very smooth. All Steppers feel warm to the touch, but the X and Z steppers have a vibration to them. The Y stepper has no vibration.
Settings:
The voltage at +5 VDC test Point is 5.03VDC
The current adjustment is set at .4VDC for each axis
Jumper Settings: J1 OFF, J2 ON, J3 ON, J4 ON
A - Red
a - Black
COM - Yellow/Blue
COM - Orange/Brown
b - Green
B - White
Computer: Gateway 2.8GHz Running XP Pro
I noticed that in the Bios config that the only setting for the LPT1 port is Enabled or Disabled.
Is there any other voltage measurements I can take to trouble shoot why the X and Z axises won't work.
I do design and assemble circuit boards for my company so any help even if a little technical will be greatly appreciated. I am not familiar with this board and don't have any schematics to go by.
I think I will go to www.alldatasheet.com and gather up some of the data sheets of the components on the board.
LinkBack URL
About LinkBacks
) I found a cheap old laptop with WIN98 and booted to DOS and ran TurboCNC and all the steppers appeared to work correctly. Now I just have to figure out whats killing Mach3 running under Windows XP.
