Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 08-03-2007, 01:13 PM
suwat is on a distinguished road
Question Expert need your suggest here... home & limit switch
I am newbie and I have HobbyCNC PRO board (3 Axis)
Before getting to smoke board.. i need to make sure .. all connect OK ?
I will use with Turbo CNC program.
need suggest.. thank you for your help
Old 08-09-2007, 05:19 AM
no expert here...
i searching and try meself.. my risk too :-)
from above diagram .. i found ...
For easy.. set 10 12 13 to home switch ...and 15 or 11 to series of limit switch ... and other for turn on/off coolant or spindle.
other process go to http://www.happyheli.com/cnc
Old 09-16-2007, 10:49 PM
mike@mikebeck.o is on a distinguished road
Hello,
Your wiring is correct. You may add as many additional limit switches in "series", as you like.
All the best
Mike Beck
Home/Limit on same switch? hargray2 General Electronics Discussion 1 04-02-2006 02:20 PM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 07:58 AM
Is it possible to use the home switch as the limit switch as well? Darc Mach Software (ArtSoft software) 2 10-23-2005 12:50 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
