Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 05-03-2007, 09:58 PM
tmd019 is on a distinguished road
Running Stepper Motors
I am having problems with one of my motors. I toggle the motor in a positive direction at different intervals. The motor will turn the correct direction during the first few intervals and then the motor will start going the other direction for an interval. I am using Mach3 and in the process of learning this program and setting up the CNC machine. My other two motors are running fine. Is there a problem with the motor or a Mach3 setting??Is there a Mach3 forum?
Old 05-03-2007, 10:02 PM
Im using stepper motors.
Old 05-03-2007, 10:08 PM
SORCHEROR is on a distinguished road
i would check the step/direction wires,make sure they are not backwards
if the other two motors work fine,check the setttings for them see if something is different on the problem one,maybe a setting is wrong,just a place to start
Old 05-03-2007, 10:10 PM
i will bet it the step and direction wires are backwards
Unsure About Running Stepper Motors tmd019 Hobbycnc (Products) 29 04-22-2007 12:28 PM
Stepper running choppy Smackre General Electronics Discussion 3 02-14-2007 08:36 PM
running stepper at 12v mikejkd Stepper Motors and Drives 2 05-24-2005 01:42 PM
Running 2 motors on the same axis xairflyer Stepper Motors and Drives 3 03-07-2005 06:31 AM
