Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 04-10-2007, 12:23 AM
arman is on a distinguished road
Ballast Resistor & 24v Power supply
hi all,
picture below is my 3 axis cnc.
bought the controller board 3 years ago from hobbycnc. one lucky day on feb 2007 start building it and get it to finished one week later. i create my own CNC software with MS Excel 2003. i name it "ExcelMill". it was fun.
for the test, i create pcb for my spindle (on/off control). the result is acceptable for me. BUT it takes 45 minutes to do the tiny job. thats not ok for me (slow). i also tested with KCAM but the max speed is only 200 mmPM.
the board is 3ADBWOHC (old) from hobbycnc. design with 3 UCN5804B ic. the BALLAST RESISTOR is 2.7 ohm 10 watt (6 pcs). the motor is 80oz-in 6v , 1.2A. threaded pitch is 2mm. my POWER SUPPLY is ATX 12v 10 amp.
from the reading increse the input voltage will make stepper run faster.
so i decide to RUN it at 24V with 2 ATX power supply connect in series.
QUESTION:
1. Will it work if 2 ATX power supply connect in series to get 24v 10amp?
2. what value for the BALLAST RESISTOR for 24v input.
thanks.
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power Supply Bleed Resistor pcstru General Electronics Discussion 3 10-17-2006 06:50 AM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
Help determining correct power resistor mvaughn General Electronics Discussion 2 04-16-2004 03:54 PM
