Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 01-25-2007, 10:00 AM
chithinh is on a distinguished road
Use Joystick to control 3 Axes.
Hello all,
Who can tell me know how to use Joystick with HobbyCNC board to control x, y, z axis? This one is easy for user to set 0,0,0 point or mill some simple shape. I don’t want to use Joystick via USB port because I have to turn PC on when do this. Give me your advice please. Thank you.
Old 01-25-2007, 11:11 AM
steve323 is on a distinguished road
It would not be too hard if you are good at electronics. I would tear apart a cheap joystick and replace the electronics with a PIC or AVR microcontroller. The HobbyCNC board needs 2 signals (direction and step) for each stepper motor. The step signal needs to pulse at the rate you want to turn the motor, and can be proportional to the joystick position. The output signals are just TTL level signals sent to a parallel port connector.
I plan on building one in the near future.
Old 01-25-2007, 07:22 PM
Thank you Steve323, When do you start? Please take a photo when you accomplish this one. Do you have schema for this one? How do you think if i make another board with joystick and combine parallel with HobbyCNC board? is it possible?
Old 01-26-2007, 11:34 AM
Sure, I will post some pictures. It may be a week or two before I finish. I have small children that limit my available hobby time.
There is not much to the schematic. The total component count will probably be 4 batteries, a 5V regulator, an AVR processor, a crystal, and the joystick potentiometers. The AVR has analog inputs that can read the potentiometers directly. The outputs can directly drive the printer cable, although I may add a buffer. I will probably also add some LEDs to monitor the input signals.
Old 01-26-2007, 12:02 PM
heyarnold is on a distinguished road
Why is a joystick needed?
I was thinking it would be easier to control and simpler to with a box that had a toggle switch and buttong for each axis. The switch would control direction (up/down for z or y and left/right for x). The button would control the steps (pulses). The pulses could be generated by a simple 555 timer chip. Come to think of it a small potentiometer could be added below each button to control the step rate (faster / slower). I thought this box would look like a pendant you see on some machines.
What do you guys think?
Old 01-26-2007, 12:15 PM
That would be an option also. A small microcontroller has an advantage that it can be programmed to shut off if the limit switches are reached. It just depends on what is easier for you to build.
I will probably make mine using potentiometers from a gameboy type controller. They are like tiny joysticks and would fit easily into a pendant type control.
Old 01-29-2007, 10:03 AM
dan dimock is on a distinguished road
schematic
I am new to all of this, just now started my build of a cnc machine. Have ordered a conrol board from hobbycnc and have not made up my mind on which software to use. If you would post pictures and schematic, I would like to look into building one.
Dan
Old 02-20-2007, 01:23 PM
Here is a picture of my joystick controller. The joystick is available from Digikey for around $6. It appears identical to the two devices found in a cheap gameboy type controller. The CPU is a 28 pin Atmel AVR microcontroller. I built it using point to point wiring, although it would have been easier to build a small circuit board.
My setup has 3 pushbuttons. One button switches between XY or ZA mode. One button selects only the strongest of the X or Y direction to allow moving just one axis in a straight line. The third button is slow mode to limit the max speed. LEDs light up to show the active axis plus plus the status of the home inputs. I also added jumpers to gang the 4th axis with the X axis because my router has 2 X axis stepper motors.
The joystick is programmed to have 100 different delay values ranging from 0.25 to 0.00025 seconds. This gives reasonably smooth control from really slow to the max limit before the motors stall out.
ID:	32169   Click image for larger version
Old 02-20-2007, 04:31 PM
joystick controller
could this be use with software where the software is use to run a program, and the joystick could be use to set the router in place if you were cutting a lot of the same pattern out one piece of wood?
Dan
Old 02-20-2007, 05:07 PM
No, that would require an input port and an output port so the device could sit in-line. I would be worried about missing pulses or messing up the timing, so I only have an output port.
It might work with a parallel port switch box although it would probably jump when switching between the two. Cheap switch boxes are not usually debounced.
  #11   Ban this user!
Old 04-10-2007, 09:02 PM
7ofclubs is on a distinguished road
I am pretty sure that Mach3 will let you do this already.
-=sHrEk=-
-=sHrEk=-
  #12   Ban this user!
Old 04-10-2007, 09:15 PM
NGinuity is on a distinguished road
-=sHrEk=-
Let you do what, exactly?
21i TB joystick.... patrickb Fanuc 7 07-13-2006 05:20 AM
joystick phe259 TurboCNC 5 03-27-2006 12:37 AM
Adding a Joystick. on7tim7 Mach Mill 0 01-10-2006 01:33 PM
Standalone Joystick Stepper Control kochevnik General Electronics Discussion 15 08-28-2005 05:22 PM
Joystick Control Sanghera DIY-CNC Router Table Machines 11 06-15-2004 11:39 PM
