Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 10-17-2006, 08:19 PM
cjchands is on a distinguished road
Smile Verify basic setup for 5Vdc to 5.2 Vdc, actual output is proportional??
Dave, I have problem posted question in group Yahoo, so hopefully experience user or Dave can help me out in this forum. Thank you.
I am just completed the basic construction for 3 axis board kit.
Instrction said to apply 12Vdc - 42 Vdc to TB6 labeled and verify +5Vdc output at te pad.
What happen is I am using Powersupply range 0-30Vdc for this test.
What I got was when I applied 24Vdc, output was 5V.
But when you applied 12Vdc (min per instruction), you only get 2V.
These values are varied from 0-24 Volts input, output to be 0-5.50 Volts.
Therefore, with your test resulted that you expected 5.0Vdc-5.2Vdc, do you mean use 24Vdc input?? Or any voltage range input between 12-42Vdc?
Old 10-17-2006, 08:59 PM
*Registered*
HobbyCNC is on a distinguished road
Between 12 and 42VDC input MUST show 5.0-5.2VDC at the +5VDC pad.
Old 10-18-2006, 12:48 AM
Red face
Darn...Then something is wrong.
With your experience, can you somewhat identify what could be wrong here?
I will overlook all the steps again, but advice would be helpful.
Old 10-18-2006, 12:49 AM
Red face
P.S. Does it have to do with all jumpers placed or not placed?
Or could it be potentiometer that did not adjust?
hmmmm..
Old 10-18-2006, 03:11 PM
Answering my own questions:
Last mosfet, last step, reverse the direction.
Old 10-18-2006, 05:10 PM
*Registered*
hmmmm..
Nope.
Reread the step about the voltage check before installing the chips. It gives a clue as to what components to check. LOOK very carefully for poor solder joints and/or bridges.
