Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
  #265   Ban this user!
Old 12-31-2006, 12:51 PM
toneV8 is on a distinguished road
diarmaid said that he will draw his own wiring diagram for Hobby controler, how he connect controler, motors, limi/home switch. There is no nothing with copyrighted material and property of Hobbycnc.
  #266   Ban this user!
Old 01-01-2007, 07:18 AM
thkoutsidthebox's Avatar
thkoutsidthebox is on a distinguished road
I think he just meant this, which is in a previous post.
I think he hasn't connected up his limit switches yet since his machine wasn't built when he finished the control box, and he was waiting to get it done first.
Sorry I can't be of more help.
  #267   Ban this user!
Old 11-02-2007, 03:17 AM
mravell is on a distinguished road
Heatsink Isolation
I have one of these stepper driver boards built.
My question is this:
When installing a heatsink (I have a nice aluminium finned job) do I need to electrically isolate the driver chips from each other?
Unless I take steps to electrically isolate them the cases of these devices will be connected. Is this a problem?
Regards
Marty
  #268   Ban this user!
Old 11-02-2007, 10:16 AM
In my case with my HCNC kit, I received one long piece of metal as my heatsink. I simply screwed this directly onto the back of all the chips with metal screws, so they are not isolated. I've had no problems. Just make sure the heatsink doesn't directly rest on the PCB itself or touch any of the leads coming out of the chips.
  #269   Ban this user!
Old 02-01-2010, 08:53 PM
vguerrao is on a distinguished road
Please, does somebody have a diagram on de SLA7078M Motor driver for stepper motors?
  #270   Ban this user!
Old 06-04-2010, 05:33 PM
kasari is on a distinguished road
Hobbycnc pro Auto zero help.
Hello,
Has anyone Hooked up a auto zero tool to the hobby cnc board?
If so, Can you help me? I'm using mach3.
  #271   Ban this user!
Old 06-07-2010, 08:51 PM
Fatboy is on a distinguished road
Originally Posted by kasari View Post
Hello,
It is connected to pin 15 and ground.
The rest of the info to get it to work you can find in the Mach3 Addons section here. My Ports and Pins set-up:
Probe: Enabled V, port 1, pin 15, Active Low V, Emulated X.
Fatboy
  #272   Ban this user!
Old 06-07-2010, 08:59 PM
amishx64's Avatar
amishx64 is on a distinguished road
No Isolation Needed
Regards
Marty
Marty, No you shouldn't have to isolate them. The contacting surface will either be non-conductive (doubtful), floating, or ground (most likely). This will be the same on the whole board, so as long as you don't accidentally attach / touch any power to the heatsinks, you will be fine.
- amishx64
  #273   Ban this user!
Old 07-11-2010, 01:02 PM
Milton is on a distinguished road
Need a little help
I have the Hobby CNC 4Axis MS HCNC PRO board and using 23-305-DS8A stepper motors and a 30 volt power supply
Need to know how to figure the Vref settings, Just not savey enough to figure it out.
Also can not find the sheet that shows the jumper setting for the board, Is someone could tell me the information on them would be great.
Milton
