Final stages!
I had to install the 6 position terminal blocks facing outwards as shown in the first pic. You can see in the pic the outwards facing by the holes for the wires, and the solid plastic 'rear' side is facing into the board. No biggie, Im a soldering pro at this stage!...The big blue things by the way.
The two position terminal blocks had to be soldered in, and the three (3) voltage regulators (Black with white tops standing up in the bottom right corner). Shown in pic 2 below. I was confused for a second with one of the two (2) position terminal blocks. It also has to be facing 'outwards' and since it's exactly in the middle I was wondering which 'outwards' it should be facing!! :hehe: Anyway, its printed on the PCB so it wasn't hard to figure out.
The third pic below shows the board after following all 20 instructions.woohoo! I still have to install the driver chips, but can't do that until I test the voltage, which is actually a very straightforward process that I'll cover later. I cant check the voltage until I get the right transformer so thats my next purchase. It might take a week or two in the post so I guess after a flying start I'm delayed for a bit.
LinkBack URL
About LinkBacks
Stick with it!
