Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 05-27-2006, 02:33 PM
jdholbrook is on a distinguished road
Dump circuit?
Just ordered my HobbyCNC board and am getting the supporting components rounded up.
I would like to run the board at 42+volts (45ish) so am considering using a dump circuit to protect the drives.
My steppers are 5.4v at 1.5a is why I wanted to run the volts as high as possible.
Has anyone used a dump circuit with the HobbyCNC board?
James
Old 05-27-2006, 04:26 PM
*Registered*
HobbyCNC is on a distinguished road
Jim,
Keep the volts below 40 for good results. That last few volts really won't make any difference in speed.
HobbyCNC.com
Old 05-27-2006, 05:03 PM
Will do then.
Old 07-06-2006, 01:09 PM
mod-rn man's Avatar
mod-rn man is on a distinguished road
Voltage reduction
I'm I rookie, & in the process of collecting parts for my machine including a commercial 48V PSU + I've pretty much decided to use the Hobbycnc board. So here is my rookie question (proably the first of many)
Following your comments about keeping the voltage under 40, how can I "adjust" the voltage downward? I can solder & have a basic understanding of components if that helps.
