That's the one. I did eventually upgrade to a nicer soldering station that has a digital temp readout where you can dial the desired temp. I'm still using the same tip and I've soldered more than I care to even count. I suppose nice solder will help from preventing that black residue from gathering on a tip. I always hated having to sand a tip.
LinkBack URL
About LinkBacks
). From there on it's a no brainer. Use a soldering iron with a pencil tip and thin gauge solder, no soldering guns here, the solder pads are too small and close together. Have courage and get to it. Regards, Mike
