Results 1 to 3 of 3
Thread: Mixing stepper motors with the HobbyCNC board?
    Feb 2005
    U.S.A.
    Hi all,
    Is it ok to use a 305oz 8 wire stepper for the x axis, and 205oz 6 wire steppers for the y axis and z axis with the HobbyCNC EZ board?
    Thanks!
    Gregg
    Registered doorknob's Avatar
    Jan 2010
    You do not need to use the same motors on every axis. As long as the motor characteristics are within the capabilities of the driver you should be OK. You can hook up an 8-wire motor like a 6-wire motor for unipolar drive.
    Depending on the individual motor characteristics, though, you may want to use different voltages on the different motors, which is not normally possible on a multi-axis driver board. If you are OK with using the same voltage on all of the motors then you should be good to go.
    Feb 2005
    U.S.A.
    Thanks for the reply, Doorknob. I just might give it a try.
  1. HobbyCNC New driver board, lower stepper prices, and NEW website!
    By HobbyCNC in forum Product and Manufacturer Announcements
    Last Post: 07-14-2006, 05:51 PM
  2. HobbyCNC New driver board, lower stepper prices, and NEW website!
    Last Post: 07-12-2006, 05:13 PM
  3. HobbyCNC board/motors for plasma?
    By Weldtutor in forum General Waterjet
    Last Post: 11-20-2005, 05:30 PM
  4. Hooking up HobbyCNC board and motors to PC...
    By jdbaker in forum Hobbycnc (Products)
    Last Post: 06-06-2005, 02:10 PM
  5. Replies: 8
    Last Post: 01-26-2005, 08:10 AM
