Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 11-08-2005, 05:10 PM
phantomcow2 is on a distinguished road
How hot should LM chips get?
The LM317 chip of my 4 axis board is getting pretty hot. My motors are running at 2Amps, I have 3. One of them is at 1.5.
It gets hot quickly after startup, not sure if this is normal or not. It has not yet shut down, i believe this is the one with a thermal shutdown so if it has not gotten that hot, i suppose thats good.
Should i try to make some type of an elaborate heatsink or what?
Old 11-08-2005, 08:02 PM
*Registered*
HobbyCNC is on a distinguished road
Does the fan blow air on it as I instructed several posts ago? It can get to 150C. Heat sink it if you want
Dave Rigotti
HobbyCNC.com
Old 11-08-2005, 08:05 PM
Fan is blowing down at it. So hot to the touch is normal then
I dont think they are at 150c
Old 11-09-2005, 06:51 PM
GrahamIT's Avatar
GrahamIT is on a distinguished road
Spit on your finger and touch the chip, it's too hot if it sizzles, so sink it.
Old 11-09-2005, 07:31 PM
Well i have adjusted the fan so it aims more toward the LM chip, the chip is cooler. Still uncomfortable to touch but im hoping the heatsink I am making tommorow will solve, or at least help that
Old 11-10-2005, 12:28 PM
GrahamIT's Avatar
How much higher is the unregulated supply voltage over the regulated, because the higher the excess voltage the more energy has to be dissipated by the regulator. A TO220 style case can sink about 25W when suitably cooled, so if you take the excess voltage being supplied to the regulator and multiply it by the current being drawn from it, you will get the wattage being dissipated by the regulator. Then you can work out the heatsink size required.
