Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 01-16-2012, 02:37 PM
crodriguez1517 is on a distinguished road
Which is better
Which HobbyCnc driver board is better the 3 axis or the 4 axis pro my machine only has 3 axis but wanted to know if there is any difference between the 2 board other than the extra axis and are this boards better than the TB6560 any reply or help will be appreciated
Old 01-18-2012, 02:18 PM
Any replies will be appreciated are they atleast better than the tb6560
Old 01-18-2012, 03:01 PM
dneisler is on a distinguished road
I do not believe there is any diff between the two, other than the 4 axis has the 4 set of axis drivers etc.
***For full up to date details visit my blog @ www.donald-neisler.com
Donald Neisler
Old 01-18-2012, 05:54 PM
H500 is on a distinguished road
Isn't hobbycnc a kit that needs to be soldered together? It's not as easy to destroy once everything is soldered together. But it is only for unipolar and 8 wire motors. It will not work with 4 wire motors.
In terms of performance, there is no blanket answer. It really depends on your motors and system. But they have similar specs.
Old 01-19-2012, 03:29 AM
Gold Member
RomanLini is on a distinguished road
The HobbyCNC kits that I have seen use the larger SLA type stepper driver chips, they are much more rugged, much larger silicon die and better at heat dissipation than the small surface-mount chips used in the TB6560.
The SLA series actually works at 3 Amps safely and continuously in an industrial type machine, the TB6560 at 3A is pushing its limits real hard and won't last in an industrial type setting. The SLA is a proper large motor driver, the TB6560 is more for little bubblejet printer motors etc although people try to use them on CNC machines.
