Results 1 to 3 of 3
Thread: Z axis zero plate?
    Registered cutter100's Avatar
    May 2010
    us
    Smile Z axis zero plate?
    Hi All, I've been searching and reading but haven't found the answer to where to hook up the 5v wire on my hcnc board? And the ground goes to the board to make the circuit right? Would really like to get this hooked up cause it would make my tool changes much better.
    Also what about the " reference plate " I've seen in some videos? how does that hook up?
    Thanks in advance.....chris
    Tinkerer
    Nov 2009
    The reference plate and tool setter are the same item (I think). Which 5v wire are you referring to? To use a touch plate you can use a piece of pc board, measure it's thickness, solder a wire to it, connect that wire to any input pin available, assign that pin in Mach. Check the diagnostics page when touching the plate to the metal of the machine, the led representing the pin it is connected to should light up. You shouldn't need to worry about ground as the machine is grounded.
    Tinkerer
    Nov 2009
    I promise I will read the original post date from now on. If this problem wasn't solved til now, I am sure you have given up. LOL
  1. Z-axis zero plate
    By Romper in forum DIY CNC Router Table Machines
    Last Post: 01-15-2012, 11:40 PM
  2. Z axis touch plate
    By spalm in forum Mach Software (ArtSoft software)
    Last Post: 10-08-2011, 02:03 AM
  3. Need help with Z axis touch off plate
    By Ed Lang in forum Techno CNC
    Last Post: 04-15-2010, 10:58 AM
  4. DIY Z axis 0 plate. It works perfect!
    By balsaman in forum DIY CNC Router Table Machines
    Last Post: 02-20-2010, 11:52 PM
  5. adjustable rod and screw plate in x and y axis?
    By josheeg in forum Linear and Rotary Motion
    Last Post: 02-10-2009, 11:37 AM
