Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 09-04-2005, 10:54 PM
bakoff is on a distinguished road
4AUPC Max Current
I was reading an article on the Yahoo CNCFoamCutter board for newbies that stated if you are using 4 1amp motors that you should double the amount of current available to 8 amps. If I'm using 3amp motors that would be 24 amps! If the HobbyCNC 4AUPC board sets the max to 3 amps per motor then what's the point of doubling the current? Wouldn't 12 - 15 amps be sufficient?
Old 09-05-2005, 02:25 AM
*Registered*
HobbyCNC is on a distinguished road
4 3A steppers will require at least a 10A power supply. More Amps the better. 24A is NOT necessary. The instructions state at least 60% of the TOTAL current draw as a recommendation.
Dave Rigotti
HobbyCNC.com
Old 09-10-2005, 04:00 PM
TimKoene is on a distinguished road
What would happen if you connected a NEMA 450 oz/in stepper rated at 5amps to the hobbycnc kit. Would it work but with less torque? Or would it burn up and self-destruct?
Old 09-10-2005, 05:32 PM
*Registered*
Tim,
Kinda dumb to connect 450oz-in steppers at only 3A. The torque will be reduced the same percentage yielding only @270oz-in. Really not an ideal system. You can..but like I said...not ideal. Use lotsa cooling air and a heatsink. Why not just get Geckos for the 5 Ampers and be done with it?
Dave Rigotti
HobbyCNC.com
Old 09-10-2005, 05:40 PM
I know, but after I ordered and paid for the hobbycnc kit (which should be enroute as we speak) I hit a solid goldmine at work! I found two 50" new IKO 25mm rails with 2 bearings each, two 50" THKballscrews with end mounts and couplings. One has a 150 oz/in stepper, the other had a whopping big 450 oz/in stepper, both NEMA-34. I also found 4 45 inch 25mm NSK rails with 2 bearing blocks each. Also two 10" THK SR-15 rails, sadly only with 1 bearing each. I am so happy, it cost me nothing at all, they were going to be tossed away!!!!! I saved them.
I do not want to take apart that beautiful THK ballscrew assembly, so I want to use it as it is untill I can afford a gecko upgrade.
Thank you very much for your reply Dave!
Old 09-10-2005, 07:49 PM
*Registered*
Well Sh!t! Free is never dumb! Have Fun!
Dave Rigotti
HobbyCNC.com
