Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 08-31-2005, 04:16 PM
jc286006 is on a distinguished road
home and limit switches
what type of switch do you need to use a momentary contact( normally open )or(normally closed) switch on the home and limit switches
Old 08-31-2005, 04:21 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Either one would work, most switches can be made NC or NO.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 08-31-2005, 05:13 PM
rustyolddo is on a distinguished road
Either will work but N/C are prefered. In the event of a failure, cut wire, it will be noticed. If a N/O switch failed or a wire were to be cut, you wouldn't know it, machine damage could result.
