Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Hobbycnc (Products)
Hobbycnc (Products) Discuss Hobbycnc controller boards here.
Old 08-15-2005, 10:03 PM
bakoff is on a distinguished road
Will these steppers work?
Salvaged 8 steppers from work (label printers) and would like to know if they are good enough for CNC foam wing cutter? Can't find any specs on either of the motors. Both are 6 wire. Would the HCNC or Xylotex controllers work?
ID:	9461   Click image for larger version
ID:	9462   Click image for larger version
Old 08-15-2005, 10:09 PM
rustyolddo is on a distinguished road
The Hobbycnc controller will drive those just fine. The Vexta for certain, the other motor you'll have to find the specs for, namely the current rating. As long as it's 3 amps or less, it will work. But you need to know so that the current limit can be set on the board.
Old 08-16-2005, 04:45 AM
*Registered*
HobbyCNC is on a distinguished road
IF using our foam cutting driver board (4AUPCWHC) then 2A is the max limit. I'm thinking these steppers are a poor choice. Look for 1-1 1/2 A 5-8V steppers.
Dave Rigotti
HobbyCNC.com
Old 08-16-2005, 07:05 PM
4aupc
Would the 4AUPC be a better choice. The bow heat control is a nice feature, but that function could be handled by another power supply, right?
Old 08-16-2005, 07:40 PM
*Registered*
Don't discount the value of auto heat control! Ask those who have it!
Dave
