| Hobbycnc (Products) Discuss Hobbycnc controller boards here. |
Hi I've just built up the hobbycnc 3-axis kit. Driver board is working fine off a bench PSU. I've built up the Psu with capacitor and rectifier supplied in kit and a 300VA transformer (30V,10A). Before I connected it up to the driver board I checked the output voltage and i'm getting 47vDC. I've checked it on a scope and i'm getting no ripple. This seems to be a bit high for the driver board. I've checked the input to the recrifier and it 29.7vAC so the transformer's giving the correct voltage out. Has anyone got any ideas why i'm getting such a high output and can the driver board take it or will it fry the chips?. Thanks in advance Matt |
| This is because it rectifies the peak AC voltage which normal AC outlets peak ac voltage is around 170v. After it is rectified and filtered, typical output is 1.414x the transofmer output voltage. Jon |
| As Jon said, (apart from UK voltage being 220 ) rectified AC to DC increases the voltage by around 1.4. If you're after 30vdc you need a transformer output of ~21vac before rectifier. Don't connect your driver to 47vdc because it will blow it.Andrew |
Dave Rigotti |
| You could always take some turns off, lowering the voltage will up the Current capacity, providing the wire size is OK, but 2amps extra coverage should be possible. Rough guide for a full Wave Bridge. VAC = 0.8 x (VDC + 2) IAC = 1.8 x IDC Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
Al
), where did you get your transformer from?Steve |
| Power supply voltage too high | spoiledbrat | General Electronics Discussion | 8 | 06-13-2005 10:39 PM |
| High Voltage wire | CNCadmin | Laser Engraving & Cutting Machines | 8 | 03-20-2005 10:00 AM |
| Transformer voltage seems too high for Gecko | bgolash | General Electronics Discussion | 14 | 12-25-2004 11:35 AM |
| 5vdc from paralell port, not enough??? | thuffner3 | General Electronics Discussion | 8 | 11-23-2004 07:07 AM |
| Active High/Active Low | Sanghera | General Electronics Discussion | 21 | 11-06-2004 09:47 PM |
