Need Help! All axis move one direction
Results 1 to 2 of 2
Thread: All axis move one direction
    Unhappy All axis move one direction
    I have stepper motor and breakout board , i had purchase it from china
    then when i connect it with PC , and mach3
    tried many time to move direction, but no way, it just move to one way
    i change every wire and double check it
    when i try to move motor to other direction
    i changed breakout board
    i changed PC ( For change parallel /port )
    i changed mach3 program
    tried every thing can , but no thing change
    Pls any one have any ideas
    be note am new in this
    Jun 2005
    Default Re: All axis move one direction
    Check the direction output, does it change from a Low to High or High to Low when you switch directions. You probably do not have the Port and Pin set correct for the direction output pin for each axis.
    Russ
