Need Help! no axis movement
Results 1 to 3 of 3
Thread: no axis movement
    Oct 2016
    Default no axis movement
    I have not gotten much assistance from the hobbycnc website, and am only making things worse trying to fix this on my own. I purchased a 3 axis pro board, and after completing the initial assembly, I had 4.93v at the test point. I completed the rest of the assembly, set the current on all three axis to .42v, and installed the board. Initially, I had very slow movement on the y axis, and none on the other ones. After a few minutes, the motor shut down as if it were going into protect mode. If I turn the board off for a few minutes and turn it back on, it goes for about 5 secs, then shuts down power to the motors again. I removed the board, verified I still had 5v, and checked the current on the axis again. I had .42 to x and y, but now have no voltage at all on the z pad. I am using a 12v pwr supply for testing and have 11.79v on the U6 regulator, and 4.93 on U5 and U7. I also have continuity on all three posts of the z axis pot. I have also verified everything is oriented correctly, and all solder joints appear solid with no bridges. I also now only have 0.006v on the y axis. I do still have .42v on the x axis. Thanks for any help, Scott.
    Oct 2016
    Default Re: no axis movement
    It appears the two pins that send signal to the pots for my y and z axis are shorted together. It is not that way on my x axis that still works. What would cause this to short together. Surely I haven't fried the driver chips that easily.
    Apr 2013
    Sweden
    Quote Originally Posted by scottmcgraw View Post
    That's impossible to answer unless we can actually repair your machine. Many things can cause a short circuit and without actually following the signals it is not possible to say why.
    https://www.youtube.com/c/AdaptingCamera/videos
    https://adapting-camera.blogspot.com
no axis movement
no axis movement
