24v 5m led strip connected to 24v fan terminal?
Results 1 to 4 of 4
Thread: 24v 5m led strip connected to 24v fan terminal?
    Member bigz1's Avatar
    Apr 2006
    NZ
    Default 24v 5m led strip connected to 24v fan terminal?
    I wish to improve the lighting on my CNC machine, Would it be possible to connect both thhe fan and a 24v 5m led strip to 24v fan terminal. LED strip is 48W total 2 AMP Max.
    Many thanks in advance.
    Member WoodWorkerB's Avatar
    Feb 2011
    Default Re: 24v 5m led strip connected to 24v fan terminal?
    If you are talking about the 24v fan voltage on a HobbyCNC board, then NO WAY! 2 amps is a helluva lot. That output is only to drive a small fan at a few tenths of an amp.
    WoodWorkerB
    WoodWorkerB.com
    Apr 2006
    NZ
    Thanks for the advice
    Feb 2008
    Afghanistan
    bigz- empty your private mesage folder!!
    all good over here. glad u didnt get flattened!
    got a few new machines and having fun!
    swapped to uccnc software to run everything now- much better than mach3.
    if your on facebook- join my group
    cnc machines and parts uk
    are you still in the place with old biesse machines?
    still doing hobby stuff?
    UCCNC powered uk machine sales
    https://cncrouter.uk/atc-cnc-routers.htm
