- need help
need help
Hi
i just bough an used kx1 milling machine and now i am trying to get it to work so installed the software from smallcnc and the xml fil for parralel port use
now the mille reacts to emergency key and the driver test say perfekt condiotions the spindle drive on small pulses just making small turns an the steppers is making a whistling sound none these reacts to joggnig or setiing spindel speed the to only ting reacting is emergency stop ports are setup like bios =epp and the adress is 378.
i used the xlm fil for pinout in mach so iam guesing those right to.
anyone have had this problem ??
regrds brian
- need help
- You may not post replies
- You may not edit your posts
Forum Rules
