- Y and Z limit switches inputs not working
Hello everyone,
I've been using a Hobbycnc EZ board with no problems for quite sometime. It's very easy to setup and works really well.
A couple of days ago I started having problems with the home/limit switches inputs, specifically Y & Z. The inputs don't pick up the signal when a limit switch circuit opens (I've set all the home switches NC), X switch and emergency stop work fine
I've searched this forum and I wasn't able to find any threads, and for some reason I cannot access the Hobbycnc Yahoo group, it's virtually impossible, better guarded than the DOD website.
I really appreciate anyone's help.
Gustavo
Re: Y and Z limit switches inputs not working
Sorry I can't help, just finishing my HobbyCNC board up now.
How do you hook up limit switches to the hobbycnc board? I'm not seeing an obvious on-the-PCB solution, but understand it's capable.
Where do you wire them into? Straight into several of the pins on the serial port?
- You may not post replies
- You may not edit your posts
Forum Rules
