Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 01-01-2010, 01:48 PM
promehanik is on a distinguished road
Building main spindle (bearings)
I am prepairing for build spindle for small grinding machine. Axial forces will be in both directions. I found this drawing. I would like remove tube which is between inner rings. This get me possibility for change bearing preload (ball bearing with angular contact) during the use. Is this acceptable? Maybe this tube have any influence on rigidity of spindle?
regards,
Promehanik
Name:	spindle Quorn.jpg‎
Old 01-01-2010, 04:41 PM
That tube or spacer controls the preload of the angular contact bearings. It also contributes to the rigidity of the spindle assembly.
Dick Z
DZASTR
Old 01-01-2010, 07:20 PM
mactec54 is on a distinguished road
promehanik
The tube is needed as it is part of the preload in this design, but the length does not have to be precise as you have the springs which give you the preload ajustment required for these bearings, for a grinding spindle you want a flat belt or a poly-v belt type not the deep vee pully in this design
Mactec54
Old 01-02-2010, 12:35 PM
I developed new design of spindle for 2 wheel grinding machine. On each end of spindle will be diamond grinding wheel (diameter 200 mm). Please tell me if bearing arrangement is suitable. Inside diameter of bearings is 50 mm.
regards,
promehanik
Last edited by promehanik; 01-03-2010 at 03:40 AM. Reason: change language of attachment
Old 01-04-2010, 11:49 AM
The bearing arrangement seems OK. I'm assuming the bearings are sealed type or there are seals in the final design.
The end with the pulley and a grinding wheel might need an additional bearing to compensate for the heavier radial load.
Dick Z
DZASTR
Old 01-04-2010, 01:12 PM
In the final design will be seals.
Maybe is better, that I move pulley on other end of shaft (near the 2 preloaded bearings)?
regards,
promehanik
Old 01-04-2010, 01:35 PM
I prepeared new design. What do you think abou it?
I want wery precise rotation.
regards,
promehanik
Old 01-05-2010, 06:13 PM
promehanic, If all your bearing life etc. calculations are correct, it should work OK.
Remember, high precision work requires high precision bearings. The higher the precision, the higher the price $$$$$$$$$$$$$$$$$$.
Dick Z
DZASTR
Old 01-14-2010, 06:28 AM
I do not want use matched bearings, because of price (very expensive).
- Please tell me if is possible matched bearings at home?
- Please suggest me any other bearings and arrangement?
On both sides I want precise rotation.
Regards, prom
Old 01-14-2010, 08:36 AM
promehanic, You will have to be more specific.
What speed do you intend the spindle to operate?, What is the maximum run out (tir)? What is the radial load? What is the axial load?
What one person thinks is precise may be different than mine or yours.
Keep working at it.
Dick Z
DZASTR
  #11   Ban this user!
Old 01-14-2010, 10:24 AM
speed: 3000 rev./min
run out: 0,03 mm
axial force: 200 N
radial force: 200 N
regards, prom
  #12   Ban this user!
Old 01-14-2010, 12:51 PM
prom, next question; what ID @ OD etc. are the bearing dimension requirements?
Dick Z
DZASTR
Open Collet While Main Spindle Spins danrudolph CNC Swiss Screw Machines 8 12-24-2009 09:44 AM
Need Help!- Milling using main & sub-spindle seesaw1 Daewoo/Doosan 18 04-05-2009 01:27 PM
rod and main bearings Hiredgun I.C. Engines 3 05-04-2008 12:46 AM
FANUC AC MAIN SPINDLE problem!! Cole84 Fanuc 11 11-21-2007 10:12 AM
How to control the speed of the main spindle? george128306 Hobbycnc (Products) 5 04-15-2006 04:00 AM
