| Hobby Discussion Discuss other CNC-related Hobbies here. |
| A great source for linear actuators is Electric Wheelchairs, I've gotten a couple here and there that were headed for the scrap yard, and there was nothing wrong with the actuators what so ever. What most assisted living centers do, is keep them around for spare parts, usually only using the footrests, wheels, arm rests, seat pads....etc. Most of them could care less about the motors or electronics. Find a couple of these facilities and talk with the Physical Therapist dept. manager... you'd be suprised what you'll find. I only know this because I used to work for a company that provided networked infrastructure for assisted living facilities. Good luck, Art |
| you havent mentioned the kind or drive( stepper/servo) or the accuracy you need. Also how cheap are you looking for, try these links: http://www.angelfire.com/az2/proff/ http://www.pro.com.sg/ |
| accuracy is not terribly important, and I am not picky on motor type. It will be for automotive use. I wish to open the heavy fiberglass tonneau cover on my truck with the flick of a switch. I was looking for something like those available from Autoloc or spal, but I don't want to pay the several hundred dollars they are asking for their models.....any ideas? |
| You could also check for power seat motors, I worked on a brand new expedition that had some sweet looking acuators under the seat, the lead screws may be a little small for your app, but you could modify longer ones if needed, some others come to mind, wiper motor, window motor, etc. These motors already have the 12v drive that you need. Good luck P.S. let us know what u come up with - i'm building a 46 ford and would like to do similar things. |
| The sattelite actuators that I saw.. Years ago... were all 24 volt DC. With or without an encoder. Maybe some had stepers.. Take a look at the number of wires from the motor. 24 volts will work at 12 volts, just slower... Can you tae the guts from the sattelite accuator, and make a mounting for a 12 volt motor? Pete |
#10
| I think I might take this project in another direction.... I found this site, and I'm gonna try to do something similar. This powers tonneau covers using pneumatics. http://www.poplocks.com/top_pop.html. Appears as though this may lift the cover faster than the electric actuators too. |
#12
| OK, I have made some progress on this one. I know it has been a while since I posted here, I was off getting married. I have almost everything I need to make the pneumatic setup work, but I have discovered that I require approx 100 psi to make my heavy tonneau move. This leaves me 2 possible options as I see it. Either fill an air tank with my home compressor and leave it in my truck (not my favorite), or find a compressor capable of pushing that psi. I got one of the mini compressors that claim 200 psi max and is powered through the cigarette lighter. Thing crapped out at like 40psi. My question, does anyone know where I can get an inexpensive 12V air compressor that will actually push 100+ psi? Also, I would like better fittings than the hosebarbs and gearclamps I am using.....any ideas? |
| Hexapod designs? | chuckknigh | DIY-CNC Router Table Machines | 122 | 09-23-2010 07:51 PM |
| CNC Router with THK KR46 actuators Finished! pics & video | wisp | CNC Wood Router Project Log | 22 | 07-08-2005 10:10 PM |
| Servos & Actuators | Moondog | DIY-CNC Router Table Machines | 4 | 07-05-2004 06:05 PM |
