Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 12-01-2004, 04:45 PM
barkster is on a distinguished road
Anyone ever machined a swashplate?
I wanted to make a swashplate and it seem like everyone is buying a certain type of bearing for making them. I doubt anyone makes the bearing for them also, anyone know what type of bearing they are using and where to get them.
Also looking for a place to find some gears but I may just use existing gears from another chopper.
Old 12-01-2004, 04:57 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Their just a normal bearing nothing special, you should be ale to get them at bocabearing. I plan I'm making my own swashplate soon.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 12-01-2004, 07:51 PM
Are you sure, all the ones I've seen have a sphere in the middle so it can spin and rotate... might want to look closer.
Old 12-01-2004, 07:59 PM
Here is rendering but just looked at my raptor and it is the same
Old 12-01-2004, 09:06 PM
CNCadmin's Avatar
Site Owner
The center is a ball, the upper part is machined to accept that ball, the upper part in sleeved into the bearing. That ball in the center is not ment to spin, it's ment to rotate and slide up and down the shaft. The inner race spins and the outter part is stantionary.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 12-01-2004, 10:01 PM
CNCadmin's Avatar
Site Owner
Maybe this will work- http://www.skf.com/portal/skf/home/p...&newlink=3_0_0
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 12-02-2004, 07:53 AM
Right, so it isn't a special bearing they are just placing the ball inside the inner race of the bearing? Seem more complicated then it sounds. Wish I had an exploded view of one or something. Thanks
Old 12-02-2004, 01:03 PM
Yes, that helped. Now if I can just find some locally or on the net. Thanks
Old 12-02-2004, 02:08 PM
ViperTX is on a distinguished road
These look allow shafts to have some misalignment within some tollerance...why the unusual name?
Need parts Machined?? tizank Employment Opportunity 32 10-24-2005 08:28 PM
need acrylic machined, pref. in los ang area ToeCutter Employment Opportunity 4 06-16-2005 12:19 AM
Machined Aluminum Part Needed Philip Employment Opportunity 2 03-13-2005 03:14 PM
RFQ-Al Machined part broken003 Employment Opportunity 8 01-31-2005 06:06 AM
Just machined a cool part ! dcarr CNCzone Club House 4 09-01-2003 10:09 AM
