Thanks for looking.
I want to add 4 different sounds (wav,mp3 etc.) and control each individually by a dry contact. Any ideas on what keyword to search or where to look.
Thank You.
Thanks for looking.
Thank You.
Not really understanding your question.
I want to use an output to execute a command to play a sound file through an amp and speakers. I have 4 different sounds I'd like to be able to use.
There are small chips which can record short segments of audio and play them back on command. Winbond is one manufacturer who makes such chips. You could also look at an mp3 decoder chip which could play data off of an SD card or something. If you provide more details about what you are doing, someone could probably help more.
Matt
