Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 04-30-2008, 04:55 PM
Skullcrafts's Avatar
Skullcrafts is on a distinguished road
Question Wooden Octagons
How do I cut out wooden octagons?
I have a chop saw and table saw to work with.
I want each octagon side equal. I want the octagon cut out of a piece of 3 3/4"W x 3 3/4"H wood.
Do I cut the diagonal sides at 45 degrees or something else?
How do I map it out?
If I can get the octagon cut, can't I use that to make more? As in, using it for a template for later use.
Need help, please.
http://www.skullcrafts.com
Old 04-30-2008, 05:54 PM
rriveraz_mty is on a distinguished road
you need to make 67.5 degrees cuts with the tablesaw in both sides of the wood when you assemble them you get an octagon.
Old 04-30-2008, 07:16 PM
I don't want to assemble them, I want a one piece octagon and then use that piece as a template for subsequent octagons. So do I set the saw at 67.5 anyway? I would assume that using a miter saw is better suited for cutting them out?
I have 3 3/4" squares to work with here, just trying to figure out how to make the squares into octagons.
Old 04-30-2008, 07:21 PM
Oh and just for an example of what I'm talking about, the following picture will illustrate what I'll be using them for. The octagon is not equal on all sides however. I want to get them that way...these were cut at 45 degrees (er...the diagonal cut). I have 4 sides equal and 4 sides that are too long.
Old 04-30-2008, 08:29 PM
enri is on a distinguished road
test
Old 04-30-2008, 08:35 PM
HeritageAmps is on a distinguished road
see if this page helps:
http://www.cleavebooks.co.uk/scol/calpolyg.htm
Old 04-30-2008, 08:42 PM
see file
File Type: dxf HELP.DXF‎ (958 Bytes, 74 views)
Old 04-30-2008, 08:55 PM
I can draw the octagon smaller if you want
Old 05-01-2008, 11:03 AM
NateTG is on a distinguished road
On a 3.75 inch square, mark 1.1 inches from each corner and clip the corners to the marks. That will cut the original sides to 3.75-1.1-1.1=1.55 and the clipped corner sides will be of length 1.1*1.414...=1.555.. (If you really care, you could cut to 1.098 inches instead to get closer to equilateral, but wood usually can't hold that kind of precision.)
Old 05-01-2008, 11:15 AM
I guess maybe I'm not making myself clear enough, I apologize.
I don't need to know how to make an octagon. I need to know how to cut an octagon out of wood. What degree angle do I need, what dimensions, etc.
What is 1.1 inches? There is no "point" anything on any rule I have.
  #11   Ban this user!
Old 05-01-2008, 12:14 PM
1.1 is between 1 1/8 and 1 3/32 you'll probably be ok using either of those depending on your tolerances.
The side length of the octagon will be 1 9/16, so if you have a combination square (or other similar tool) that you can slide along the corner till a 45 degree line has that length, then mark and cut.
Old 05-01-2008, 12:41 PM
ger21's Avatar
.1 = ~13/128"
My First Wooden Cut NetStorm WoodWorking 9 09-12-2007 08:23 AM
wooden sandals mohop WoodWorking 17 08-15-2007 06:49 PM
my cnc wooden table. steve knight CNC Wood Router Project Log 4 04-09-2007 10:48 PM
Wooden Gears? spalm Autodesk Software (Autocad, Inventor etc) 13 03-05-2007 10:39 AM
Epple Wooden CNC keyne DIY-CNC Router Table Machines 7 04-04-2006 01:49 PM
