Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 01-02-2008, 08:16 PM
ahillworks is on a distinguished road
New Sorry!
OK wow first off to the amount of info I have scanned threw. Some of you people are awesome at what you do. To the point. I need help knowing what I need to make Molds for RC Cars I am going to making using a Vacuum Forming machine I have built. I will go as far as making a CNC machine but need to know how many Axsys I need and ect... All the help would be great. Thanks Anthony.
Old 01-04-2008, 04:14 PM
awerby is on a distinguished road
[For this, a 3-axis mill or router should work fine. You can't have any undercuts in your vacuum-forming model anyway, and a 3-axis mill will not produce any, due to its configuration. Figure out the largest part you'll need to make and plan the axis travels accordingly, realizing that you'll need a little extra to reach the edges of your part with a tool.]
Andrew Werby
www.computersculpture.com
Old 01-04-2008, 04:54 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
What material (wood, alum. etc...) will you be cutting?
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 01-04-2008, 05:21 PM
neilw20's Avatar
neilw20 is on a distinguished road
Question Cost?
How much do you want to (need to, can you) spend?
Any job bigger than a big house brick?
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 01-04-2008, 06:13 PM
epineh is on a distinguished road
Have a look at the JGRO plans, or even the Joe2006 plans, should be more than enough for what you need. The smaller you can make a machine the easier and cheaper it will be, at least for a first machine. You already have a purpose for it so you would probably be best off catering for that, rather than build a machine that will do everything.
The JGRO and Joe2006 are free downloads from this site and there are heaps of open source stepper drivers around, it will take a little research on your part but well worth it.
Good Luck !!
Russell.
Old 01-22-2008, 06:16 PM
Cool thanks for the input was going to use wood or foam to make about 10th scale rc car molds. Any suggestion on premade machines I can buy. Nothing big really since its can be done on a desk if needed. I would say no bigger than 2 x 2 feet square space to work with. I think in this part of my business Id better buy this machine rather than make it unless its easy to make?
