Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 12-21-2007, 03:49 PM
deanbrock is on a distinguished road
Band Sawmill Idea
Simple idea. Take a junked/rusted vertical band saw from ebay, get it in working order, mount it horizontally over track. Waa laa. Eletric band sawmill, on the cheap.
But I haven't seen anyone do this yet. Can anyone think of any reasons why it wouldn't work?
Thanks,
Dean Brock
Knoxville, TN
Old 12-22-2007, 10:52 AM
It's been done and they are also commercially available. Often the people who sell log splitter kits sell band type sawmills, usually they are portable as well. When portable, they are normally powered by IC engines of some type.
Your idea of "doing it on the cheap" is appealing though.
Dick Z
DZASTR
Old 12-23-2007, 07:38 PM
Dean, You piqued my curiosity so I googled "portable saw mill". They are available from $199 to $$$$$$$$$$$$ Some look like your idea and some are like chainsaws in a horizontal frame. Seems like a popular machine.
Dick Z
DZASTR
Old 12-26-2007, 07:05 AM
BobF is on a distinguished road
You would need a stought saw for that. Most vertical saws dont have the guts to cut a whole log. Most common saw is a 14", but they usually only have about 6" vertical clearance. You have to a add a riser block to get 12" clearance. You would also have to choose the blade to suit the task. Get a 3 or 4 tpi blade with a "skip tooth" configuation. Since you will mostly be cutting with the grain you need all the chip clearance you can get.
Old 12-26-2007, 12:42 PM
I still like Dean's idea. What if you rigged up one of those combination vertical/horizontal band saws and squared the oversized log. After you remove the rounded "caint's" (cain't use em fer nuthin), the log might fit the throat. We had such an old band saw that had a 16" throat and used 1 1/4" or 1 1/2" blades. If my fuzzy math is correct, you could start with a 22 1/2" dia. log. If that would work, why not? Might be fun, expensive, waste of time, PO the significant other or all the above. lol
Dick Z
DZASTR
Old 12-29-2007, 06:03 AM
Oakley1975's Avatar
Oakley1975 is on a distinguished road
Thumbs up Check out this forum...
Theres lots of info on diy builds and homemade mills here....
http://www.forestryforum.com/board/index.php?board=7.0
I've been a member for years.. Lots of info and good people.
band saw blades star1280 General Metalwork Discussion 8 06-27-2007 05:51 PM
band saw blades BeeleJuice General Metalwork Discussion 5 11-07-2006 10:07 AM
Band Saw Barry_ward General Metal Working Machines 3 08-12-2006 09:04 PM
Band Saw Hellbringer General Metal Working Machines 7 01-07-2006 11:42 PM
Band saw cnc wizard WoodWorking 0 04-01-2005 08:37 AM
