| Hobby Discussion Discuss other CNC-related Hobbies here. |
Hi there I built a first prototype of stepper controlled coil winder using the following architecture : • PC interface in MS Excel • VBA code to do the maths according to wire gauges, # turns etc • Mscomm32.ocx to send communication to COM4 port • FTI USBMOD4 device (http://www.elexol.com) to use USB interface • Bit 0 pilots the coil stepper driver: Qasar 3179 unipolar driver (http://www.quasarelectronics.com) . Current regulation (4.5A) uses a simple and old-fashioned power resistor. The motor is 86HY62DE04 from http://www.3xmotor.com • Bit 1 pilots the wire guide stepper driver: Qasar 3158 bipolar driver. The motor small motor has been salvaged from an old fax machine. The system works BUT in my opinion the rotation is not smooth and regular. Sometimes the motor groans and waits. This is not satisfactory and I am seeking for advices. In my opinion flaws could come from • VBA + Mscomm32.ocx: not reliable enough? • USBMOD4 interface: tuning of capacitors between RXE and RD? • Qasar drivers? • Motor Current regulation? Can anyone of you give advices, feedback, hints? MANY THANKS Guy |
| Maybe a combination of issues. USB has high latency, so you could possibly be seeing a variance of pulse timing. Second issue would be the full step Qasar driver, you would gain by going to at least half step, if not quarter or eighth. There is a lot of difference in motor smoothness between full and half step, and each subsequent microstep size.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| Guy The VBA is very unreliable when it comes to maintaining timing. The USB has a built in 1 ms latency. That's the time between when you tell it to send data till it actually gets sent. I had to add processor on USB end to get sweet step signals. Dennis http://www.super-tech.com |
| Computerized Coil Winder Build in Progress | vacpress | Musical Instrument Design & Construction | 6 | 05-10-2008 07:20 AM |
| cnc controlled mandrel bender controlled by mach3 | timmyb199 | Bending, Forging,Extrusion... | 5 | 05-30-2007 06:35 PM |
| Transformer Coil Winder | cjenrick | General CNC (Mill and Lathe) Control Software (NC) | 9 | 09-17-2006 09:43 AM |
| Coil Winder | itsme | I.C. Engines | 6 | 08-25-2006 01:12 PM |
| Filament Winder | RotorRouter | Open Source Controller Boards | 0 | 05-29-2005 07:18 PM |
