Results 1 to 5 of 5
Thread: Very Small cutter
    Aug 2006
    UK
    Very Small cutter
    Hey Guys
    I am trying to make a very small propeller around 0.35" in diameter, my problem is, how the hell can I mill it? the smallest tool i have is a 0.05" end mill, but it obviously cannot get in between the blades, can you get smaller cutting bits? I want to cut it out of 0.06" thick aluminium. I have not figured out 3D drawing yet so is simply a cut out of a shape.
    Any ideas on what I could use?
    DJH
    Aug 2006
    UK
    Have not figured a way around it, but instead I used 0.009" thick brass with a 30 degree engraving bit, as it was so thin it only used the point of the engraving bit, making it effectivley a very small diameter tool. the added bonus is that i can bend the blades to give a 3d propeller effect.
    DJH
    Mar 2005
    ENGLAND
    Aug 2006
    UK
    ooh Thats great thank you
    I did not know they could be used that small
    once again thanks for your help , will order some later
    DJH
    Jan 2006
    www.kodiakcuttingtools.com
    has them down to .005"
    Matt
    1. Portable CNC Cutting Machine Makes CNC Cutter Affordable for Medium and Small Enterpr
      By denniswang in forum Product and Manufacturer Announcements
      Last Post: 02-08-2012, 08:44 PM
    2. Tool & Cutter Grinder and Wire Cutter Plans
      By newport in forum CNC Wire Foam Cutter Machines
      Last Post: 04-17-2009, 05:15 PM
    3. How do I use a dove tool cutter & slot cutter
      By bobby1 in forum BobCad-Cam
      Last Post: 04-15-2008, 09:06 PM
    4. Madcam 2 cutter too small
      By baldysm in forum MadCAM
      Last Post: 07-26-2007, 03:16 PM
    5. How to position cutter on a lathe and which cutter to use?
      By alexccmeister in forum General Metal Working Machines
      Last Post: 06-17-2007, 02:26 PM
