Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 04-01-2007, 10:25 PM
Skullcrafts's Avatar
Skullcrafts is on a distinguished road
Question Making Miniature Bases
My dilema: I have never used a router before and I need to make use of one to create hundreds of miniature wood bases (kind of like what you see on small trophy displays).
My equipment: I have been using Dremel tools for nearly as long as I've been crafting. I trust the name and use the tools on a regular basis. Thus, seeing the need for a router, I've bought the routing attatchment for my dremel.
Dremel variable speed rotary tool
Dremel router attachment
My materials: I will be using oak wood to make these miniature bases. I have strips of oak as follows:
¼" thick x 24" long x 1½" wide
¼" thick x 24" long x 2½" wide
¼" thick x 24" long x 5½" wide
½" thick x 24" long x 1½" wide
½" thick x 24" long x 2½" wide
½" thick x 24" long x 5½" wide
¾" thick x 24" long x 1½" wide
¾" thick x 24" long x 2½" wide
¾" thick x 24" long x 5½" wide
Here are my questions so far...
#1. How to use the Dremel router.
What do I need to set it up?
Do I need to have it mounted to a table?
Are there bits available (for the Dremel) to make this a one-step process?
#2. What to use.
Do I need a template to make the bases?
How do I make a template?
Can I purchase pre-made templates or have one custom built for me?
#3. Dumbing it down.
Can I use large dowels to make these bases from? and I mean if I bought a 2" round dowel and cut it on it's side and then routered the edges, would that be doable?
Are there any practical ways to make these items at a faster rate?
Any and all help is very much appreciated. Thank you.
Old 04-01-2007, 10:32 PM
Examples of miniature bases
http://www.michtoy.com/MTSCnewSite/s...rea_bases.html
http://www.skullcrafts.com
Old 04-28-2007, 07:01 AM
Wargamer is on a distinguished road
You could probably get Ken at Litko to bang them out fairly inexpensively:
http://litkoaero.com/
He'll do custom wood jobs.
Old 05-25-2007, 08:55 PM
JavaDog's Avatar
JavaDog is on a distinguished road
Might have missed it, but are you looking to do rectangular ones or the round ones?
If round, I would suggest a lathe...and there is even an inexpensive option that might do the trick for you. I saw a post on Tool Monger about this little guy, for not-high-volume work, looks like it could be a cool intro to a real lathe tool. Should be able to make your round stands on it as well...just a thought...
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
Old 05-25-2007, 09:02 PM
cacrawfo is on a distinguished road
Hello,
Not to pee in your Wheeties, but a Dremel might not really have enough balls to do any serious routing. For what you are doing, I think the best thing to do would be to cut blanks with a table saw, then mount the router upside-down in a router table and finish the edges with whatever style bit you want. They make many different form styles, and I think it is reasonable to say that you could do each edgae in one pass. A Router table makes it easy to slide the work safley past the bit, and you can do rounds as well.
If you want to make round bases, you could use your flat stock and a hole saw in a drill press. If you clamp the wood solidly to the base, you can remove the pilot bit from the hole saw. If you do not mind a hole in the center, you can leave it in.
In short, I would suggest getting a $100 router with some power, a cheap plastic Harry homeowner router table, and the router bits you like.
Free Granite for Machine Bases DGoncz Mechanical Calculations/Engineering Design 6 09-29-2007 01:36 PM
Miniature Pneumatic Switches skmetal7 Mechanical Calculations/Engineering Design 4 06-08-2006 04:09 PM
Miniature Actuators Robyn Product Announcements & Manufacturer News 0 03-10-2006 01:13 PM
