Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 03-06-2004, 04:32 PM
njtermite is on a distinguished road
Hand held band saw?
I was wondering if there was anything like a Hand held band saw? I need to cut a shape out of wood. A band saw would be ideal for this, but I don’t have one. So I was wondering is there was any hand held power tools that you would recommend?
Thanks,
Mark
Old 03-06-2004, 05:22 PM
HuFlungDung's Avatar
Moderator
How about a jigsaw?
Stevenpats is on a distinguished road
A jigsaw is probably what you are looking for, yes there are portable band saws, but not too handy for curve cuts.
Steven
Old 03-06-2004, 05:55 PM
Would a jigsaw cut out something like an electric guitar shape? Also what is the name for the portable band saws, were could I find one at? Also what blades do you recommand?
Mark
Old 03-06-2004, 06:06 PM
also what about a Cut-Out Tool ? is that what the tool is for as well?
Thanks,
Mark
Old 03-06-2004, 06:39 PM
Hobbiest is on a distinguished road
The portable band saws offered don't have much throat depth. They are also competitively priced with the low end band saws offered by companies like Grizzly, or Harbor Freight. A jigsaw would be capable of the cutting you need, but you will want to take it slow, and cut oversived, sanding to the finished line. Sometimes on a thick piece, the blade will cut at a downword angle, instead of perpendicular to the work surface. That is why I say to take it slow. I have personally cut through 2.5" thick work with one.
Stop talking about it and do it already!!!!!
Old 03-07-2004, 01:53 AM
Verboten's Avatar
Verboten is on a distinguished road
Hello!
I think that you would be a lot better off if you made a thin pattern and used a router to copy it in thicker stock.
Old 03-07-2004, 08:34 AM
wjbzone's Avatar
wjbzone is on a distinguished road
A chain saw might be an option.
Bill.
Old 03-07-2004, 06:36 PM
rob2424 is on a distinguished road
i have a sawmill
Old 03-07-2004, 09:50 PM
anoel's Avatar
anoel is on a distinguished road
A jig saw will do the trick. I've used one on several occasions to cut out guitar bodies. The big draw back is that you wil not get the cuts perpendicular to the top and back and you will need to use a drum sander or oscillating spindle sander to square them up. You can probably look in the phone book and find a woodworking shop or cabinet shop that would cut out your body for a few bucks, just bring your wood and pattern to them and see what they can do you for.
Nathan
