| Hobby Discussion Discuss other CNC-related Hobbies here. |
| Hi folks, Building my own wind turbine has been on my list of 'to do' things for a longggg time now. And it probably will remain on the list for a long time! But, Im wondering has anyone here built or bought their own turbine, and I thought that if I could drum up some interest I might get some useful info for when I eventually get around to doing one myself. I figure in my own case I'll stay off the grid, and use a battery system, since in Ireland at the moment there's no payment scheme for producing excess, and no tax breaks. I can run wires from the battery system into my workshop (Which isn't built yet..next year) and into the new house (Which isn't bought yet...next year) . And I'll have seperate plug sockets powered from my batteries. I figure I'll always plug the tools and some household appliances into the battery powered wall sockets until they run down, then plug into the regular sockets. Cnc machinery and computers obviously will nearly always be connected to the regular mains in case the batteries drain. I figure I'll use 20 12V lead acid batteries to generate 220V then step down to the workshop for 110V and run direct to the house (After DC/AC conversion) for the household 220V.There's lots of info on the net but I have a few electronics questions. 1) Is it possible to get a 110VDC to 220VAC inverter capable of handling a max load of about 4KW? I haven't seen any on the net but I think it might be cheaper to just buy 10 (Instead of 20) lead acid batteries for 110V and step up for the house since the extra 10 btys are a lot of extra expense. A lot of off the shelf systems I have seen seem to output 24V using two lead acid btys. I can't see how 24V is useful for anything? I have a 24V DC to 240V AC inverter I got for a previous project (About €90 I think), but nothing like the wattage capacity needed for this. 2) I understand that I need some sort of battery voltage regulator so that when the batteries are fully charged any power coming from the turbine can be diverted, so as to avoid causing excess hydrogen from the bty's, and possibly an explosion . How does this work and where is the turbine power diverted to (Ground possibly...)?3) If I could get a 24VDC to 220VAC inverter would that be a good way to go with only 2 bty's, or is there any reason I should have 10 bty's giving 120VDC and use an inverter to get 220VAC? (More reserve capacity for those days with no wind possibly...) Thats it for now. Thanks all. Last edited by diarmaid; 11-18-2006 at 03:19 PM. |
| They have recently installed some windfarms close to where I am and the govt have published some details on individual stations, I haven't read it but you may get something from it, The full size windfarm units are HUGE. http://www.smallwindenergy.ca/en/SmallWind.html Al.
| Thanks Al. The more info the merrier. Im sure someone out of the zone's 40,000 members have had experience with this type of thing before. With all those workshops, the savings from having your own electricity generation are huge! Do you have any suggestions on questions 2 & 3 above? |
__________________ HayTay Don't be the one that stands in the way of your success! |
| I have been building savinous type vertical axis wind turbines (VAWT) and find it to be very interesting to see how the wind and the rotor react. This kind of hobby does take some engineering to get some good results. There are many sites with info on how to design and build. Some of the parts can be cut with CNC, some have to be done by hand. I am working on my third design and hope to have this one turning a generator. Rippersoftware |
Question 3, the lower your primary voltage on an inverter (stepping up in voltage) will mean a higher current draw. If you have a battery voltage similiar to what you are "creating" with you inverter, the batteries will "see" a similiar current. Halve the battery voltage you double the battery current for the same secondary current and so on. There are other factors involved but this is generally the concept. Power is given as P=VI where P is power, V is voltage, I is current, so you can see for the same power consumption, if you change the voltage you can calculate what the current will be. I'm keeping things simple here, there are other factors that influence all of this in an AC system like load types - resistive, inductive and capacitive that will affect current draw by changing the load's power factor, which will affect the equation, but that is a whole other story. One word of warning though, if you decide to link a heap of batteries together to reduce battery current, take EXTREME care in your connections and layout, I would suggest installing fuses on the battery "string" output, and a couple of removable links in series with the batteries every 4 or so batteries to cut supply to work on or replace batteries. There is no other way of turning off a battery bank, and fault current conditions are just as nasty if not worse than grid powered cabling. I have heard some real horror stories with DC supplies if you want to hear one, suffice to say they can bite so a little safety goes a long way. Good luck if you go ahead with it, I would like to be self sufficient power wise myself but cannot work out a decent way (yet) to do so that doesn't involve the use of large batteries. Russell. Last edited by epineh; 11-19-2006 at 06:31 AM. Reason: tiepoze |
#10
| Hi Diarmaid. I've also got the wind turbine project hovering on the to do list, and with the season cooling down, it's rising up the list fast ! Our take on using the power is not to go for batteries, but to use the current to heat soil directly with soil cable under the greenhouse. This means I don't have to worry too much about varying voltage/current. If my prototype setup works, the next step is to build a bigger one as a water heater for the house, either for space heating or pre heating the hot tank. Then on to making the solar powered unit in the spring.................... John
__________________ It's like doing jigsaw puzzles in the dark. Enjoy today's problems, for tomorrow's may be worse. |
#12
| Thanks for all the replies and interest folks. I have visited that other cnczone thread and read it all. Quite interesting but no links for the various material sources and Terry's site is gone. I think I'd prefer to buy a 48V Permanent Magnet Generator off the shelf than build my own. Maybe build my own at a leter date as a project, but the electronics is my most difficult part.Under soil heating for a greenhouse, never heard of that before! Sounds interesting. How is 'soil cable' different to normal cable. Never heard of it either? Thanks for answering my questions epineh, I hadn't thought about having disconnects in series but definately a must do with any system above 12V. Are there any specific reasons why you don't want to go with bty's apart from what you have already alluded to? Although I dont really have a choice, its always good to know the 'cons' of a system aswell. ![]() Thanks for that list ripper, its gonna take me a while to get through it all! I would be hoping to build about a 3 or 4 KW per year system. Not sure how viable this is, but since avg Irish household use is 5 to 7 KW useage, and I want to have a full time business running from my workshop, it'd make a huge dent in the electricity bill. Irish electricity prices have gone up over 90% in the past 5 yrs, in an misguided attempt to entice private competition into the market but thats a different thread! That first inverter link was just what I was looking for, 24VDC to 110VAC 7000W peak! Already further along. But then I have to step up again to 220V for the house.....Although even if I could provide power to the workshop it'd make a huge differance. I saw a post before on the zone where someone had bought a plasma cutter and was asking if it was normal for his electricity meter to be spinning rapidly when using it!! |
