| Hobby Discussion Discuss other CNC-related Hobbies here. |
Problem Statement: Fabricate a remote controlled boat that should be able to traverse a straight water channel (~ 30 meter long) in minimum possible time. The Machine: I. Power · The boat should not have its endtoend dimensions exceeding * Lengthwise: 75cm * Widthwise: 30cm * Depthwise: 25cm · It can either be powered by a (single) IC engine OR a (single) electric motor. Use of any other kind of power source is strictly prohibited. · If powered using an IC engine, it should not have its capacity (displacement volume) more then 3.2cc. And if powered using an electric motor, a potential difference greater than 24V should not be present anywhere in the model at any point of time. II. Control · The model should preferably be maneuverable using remote control. The controls may be for basic functions like steering, or even for more advanced ones like throttle control. · Participants may use a separate power source for the steering mechanism as long as it does not contribute in anyway to the forward thrust to the boat. · However, if the participants think that they don’t need to control the boat once it leaves the starting line, they may save themselves the trouble of making the remote control. · Those participants who choose to use an IC engine; they are allowed to start it well before the race starts. The boat (with its propeller) may be kept in air with the engine running, and then let go as soon as the start signal is given. If they can devise any other better method they are welcome to do so. III. Design · The participants must fabricate the hull of the boat themselves. We suggest the use of FRP as it is the easiest to work with and best suited to our needs then other alternatives. · It is expected that the participants will do the whole mechanical assembly of the power, steering systems etc themselves. · However, they may borrow some basic parts like a propeller etc from premade models. We will still suggest that you make as many parts yourselves as possible, so that they best suit to your needs. |
