Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
Thread: picture for dxf file?
  1. #13
    May 2004
    If you are using Rhino, I have no idea of the commands. If you press the F1 key, does a help window pop up? If so, search for "mirror" in the online help.
    http://www.kirkcon.com/
  2. #14
    Feb 2012
    EASY
    i didn't realize there was a bar up top that you can type into and give commands, all you do is select the image type im mirror then select were you want it!
  3. #15
    May 2004
    Slaps you in the face sometimes.
  4. #16
    Mar 2012
    Quote Originally Posted by strawn52 View Post
    i do understand how to rotate and move the letters... i just need to know how to mirror images if possible
    I suggest that you use Photoshop to mirror the image, there is such a feature, it's called "Flip horizontal". Then you could save the image and continue editing it in the program you usually use.
    [URL=http://m4atomp3converter.org/][SIZE="1"]M4a to mp3 converter[/SIZE][/URL]
  1. Replies: 7
    Last Post: 12-10-2010, 10:04 PM
  2. Replies: 3
    Last Post: 02-26-2010, 02:40 AM
  3. picture file to G-code
    By zachjowi in forum LinuxCNC (formerly EMC2)
    Last Post: 12-22-2009, 12:26 PM
  4. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 02:14 PM
  5. Picture to cad file
    By bogger44 in forum General CAM Discussion
    Last Post: 05-01-2007, 08:05 AM
