Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 01-27-2012, 08:55 PM
riche543's Avatar
riche543 is on a distinguished road
2nd Build
Hi all
Just wanted to share a few early pics of my 2nd cnc build. Just over 2 years ago I built a mdf / skate bearing cnc which has done me very well, but think its time to upgrade to something more solid, the main table is a 10mm thick steel plate which weighs about 80kgs size is 1200x700. So my cutting area will be slightly smaller than this. I will be making as many bits for the new build with my old machine as I'm able too cut upto 12mm aluminum so motor mounts , z axis design will be cut out on old cnc. I have 3 425oz nema motors for the axis, all ball screws are 25mm . Feel free to ask any questions but I will more likely be asking all you guys for your opinions . As with a lot of us I'm sure finding time for our hobby can be hard sometimes , but will do my best too keep this updated as I slowly progress
Enjoy.
Riche
ID:	151302Click image for larger version
Old 02-04-2012, 05:46 AM
riche543's Avatar
Very small update
Got the Ball screw installed on the Y axis & Rails on the X axis,
next will start the mounts for the X ball screw & cut some motor mounts.
ID:	151899   Click image for larger version
ID:	151900   Click image for larger version
Old 02-06-2012, 06:52 AM
tumutbound's Avatar
tumutbound is on a distinguished road
Steel plate! I've never seen lifting handles on a CNC before - although it's not a bad idea, I have a 6040 machine and it's a pain to move.
Do you get much flex from the unsupported rails?
Regards
Geoff
Old 02-06-2012, 02:08 PM
riche543's Avatar
Hi tumatbound
Yeah thought handles would be a good idea , so when I ask my neighbor too give us a lift he can't complain, lol. Once in position will remove handles. Fingers x there's not too much flex on the Y at the moment, the ball screw is 25mm so that shouldn't flex much. I am fitting a floating Z axis head for engraving so hopefully should not be too much of a problem (pic attached). I do feel like maybe I should have got supported rails now , but will see how it goes
Cheers
Riche. Click image for larger version
Old 02-08-2012, 09:50 PM
riche543's Avatar
Another small update
Shows nema motor mounts , would have liked too have made them out of a whole block but I can only cut max 12mm deep with my old cnc , but these seem too work ok. Also back plate of X/Z axis engraved face was just playing around, don't think it will be too visible once the rest is attached
Cheers
Riche
ID:	152292Click image for larger version
ID:	152295Click image for larger version
ID:	152296Click image for larger version
ID:	152297Click image for larger version
Old 02-12-2012, 04:31 AM
craigjh is on a distinguished road
Nice work Riche.
I too have built an MDF version CNC (JOES), but now half toying with the idea of constructing a second one using some alloy like yourself.
I haven't actually tried cutting Al yet. I'd be interested in what cutter/rpm/feedrates you're using, as it looks like you're getting a reasonable result!
Keep the posts up, we'll be following along mate...
- Craig.
my JOES2006 build thread - http://www.cnczone.com/forums/showthread.php?t=106995
Old 02-12-2012, 11:44 AM
riche543's Avatar
Hi craig
Thanks for the nice words,
I do struggle a bit cutting ali as the mdf machine isn't really rigid enough, normally just cut plastic, I'm using 3 mm end mills for Ali & the speed/feed rates are far from normal machining . Some times it will cut at 240mm per min with 21000 rpm & 1.5mm passes other times that will snap the bit ( have gone though a few already) but I have found that 60 or 120 mm per min with same rpm & passes works better. Most days. It's the chatter that snaps the bits, one day you think you have found a nice speed , next it doesn't work , normally snaps on last pass , oh also using air too blow away chips.
The guy I buy the end mills from in the US is properly wondering what I'm doing with all these 3 mm end mills lol.
Cheers
Riche.
Old 02-13-2012, 05:39 AM
Al cutting...
Ok, sweet, thanks for those stats. I'll see how I go. My other hesitation is blowing those Al chips everywhere...! What a pain.
Hey I also noticed it looks like you have a vacuum table yes...? How's it go? Very handy for holding down the thinner sheets of mdf/plastic I imagine.
- Craig.
Old 02-13-2012, 01:17 PM
riche543's Avatar
Hi craig
Good luck with it but I do go though lots of end mills with chatter, have found sometimes not cutting all the way though , leaving 0.5mm may help ?. I could not find the post that talks about blowing chips out, but I bought the pump that was recommended , it's a large pond air rater , wasn't expensive but works well, eBay sell them ,
Cheers
Riche
Old 02-13-2012, 01:42 PM
riche543's Avatar
Craig
Just looked at my air pump , it's a hailea aco-009d , works great.
Also I know might look like vacuum table on my old build , but it's just hundreds of holes that I thought I might have used for holding stuff down , but didn't work as expected, so there just for show, lol. Ended up using double sided tape.
Riche.
  #11   Ban this user!
Old 02-17-2012, 11:50 PM
riche543's Avatar
Only got a small amount done this week, but moving forward not backwards is good .
So cut all X ball screw mounts & installed X motor , Tested once installed & running smooth
Cheers
Riche.
ID:	153043   Click image for larger version
ID:	153044   Click image for larger version
ID:	153045   Click image for larger version
  #12   Ban this user!
Unread 05-26-2012, 06:34 PM
riche543's Avatar
Ok things are just about finished few add ons I would still like too add like superpid & x360 control.
Very happy with results so far, Here's some more pics.
Heres a close up of the hall sensors used for home/limit switches.
Dust shoe which also shows the 2 small air pipes which cools the tool while cutting
Pump for air cooling with heat sink & fans as the air leaving pump gets warm.
G540 driver , I used some scrap 12mm aluminum for heat sink with thermal paste. Glued on with epoxy.
Built an enclosure for electrics with extra 12v & 5v on front & back if needed
Also ins & outs on g540 are connected to terminal block on back for easier connection.
Cheers
Riche.
ID:	160524   Click image for larger version
Mint's Build Aluminum/Steel Build thread. FreshMint DIY Discussion 0 10-30-2011 10:18 PM
Need some direction to build a small machine to allow me to build a larger one Dman65 DIY-CNC Router Table Machines 1 07-28-2011 09:05 AM
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
Joe's 4x4 hybrid build/2006 build krap101 DIY-CNC Router Table Machines 1 08-09-2010 05:30 AM
