| Hobby Discussion Discuss other CNC-related Hobbies here. |
| Hello there! My project consist in automating a "track saw" that I own (I build small wood boxes). and I know there has to be an easier way to make repetitive cuts... as I did not find any solution... Im building it!! The "tracksaw" is a guide system that allows the circular saw to slide and cut straight pieces of wood. I attached a picture so you guys can have an idea of it ![]() My goal is to use a leadscrew drive system like this one cjamasterworks to build a carriage to move the saw back and forth with a push of a button so to speed up my cutting time and sound as I want to enclose it!! The total length of travel is 64". Im planing to use this Leadscrew: Major Diameter: 1/2" (in.) Threads Per Inch: 8 (Threads/in.) Number of Starts: 4 Lead: .500 (in./rev.) Effective Threads Per Inch: 2 (Effective TPI) Hand: Right Hand where I REALLY NEED HELP is in figuring out how much power and torque will I require to make the saw move back and forth and cut wood at 1 1/2 inches thick at most. Also do you think that the half inch .500 lead leadscrew be enough to move it steady? The saw weights 8 pounds! would a nema 23 276 onz/inch be enough? Thanks a lot!!! Cj |
| You may find some helpful guidance in sizing of components here: http://www.massmind.org/techref/io/s...htm#Estimating |
after talking with Chris from cjamasterworks.com (really nice and helpful fella) I will go with a nema23 570 oz and a 3/4 leadscrew with .500" lead for my project! Cj |
![]() It's really interesting to see that sort of rack and pinion driver system they use, gives me ideas what I have thought using in mine is a leadscrew linear drive system... I'm still thinking about what kind of rails I'll build for my machine but seeing what others had done expands my horizon.thanks again! Cj |
| Tags |
| automation, circular saw, guide |
| Nordic Automation / Eu-Automation | Swemill | Norwegian Club House | 1 | 03-15-2011 07:10 AM |
| Need Help!- Circular Cut | mikelohj | LinuxCNC (formerly EMC2) | 1 | 06-18-2009 12:19 PM |
| Drill Press Speed Guide, Band Saw Speed Guide | zerodegreec | General Metal Working Machines | 0 | 02-27-2009 12:12 AM |
| What do you know about this circular saw??? | mailloux | WoodWorking | 5 | 10-16-2007 10:34 PM |
| Circular Cut | Sanghera | GRZ Software- MeshCAM | 13 | 11-13-2006 10:26 AM |
