Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 05-17-2011, 08:12 PM
ahab8783 is on a distinguished road
Timing belts vs. Ball screw
I'm working on a DYI mill/router (not sure which one yet) and was wondering what are the general pro's and con's to using either timing belts or ballscrews for linear motion. Obviously ballscrews are more expensive than belts, but would I really need them if I'm planning on cutting only wood and soft metal (i.e. aluminum, copper, tin.)
Changing from Timing Belts to Lead Screw X and Y axis Schweinhund227 DIY-CNC Router Table Machines 6 03-19-2009 11:48 AM
Timing Belts kingpav Linear and Rotary Motion 1 09-28-2008 09:54 PM
Ball screw or Timing belt skazic Linear and Rotary Motion 7 06-27-2007 05:14 PM
Ball screw, Timing belt or Rack and pinion abomination Linear and Rotary Motion 10 04-30-2007 10:14 PM
Timing belts, why not use? wwminc Linear and Rotary Motion 10 09-03-2005 10:03 PM
