Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 03-14-2011, 06:16 AM
Ashish B's Avatar
Ashish B is on a distinguished road
Cool Which material for BEARING
Hello,
I am designing a PLAIN BEARING arrangement. The shaft oscillates in a PLAIN bearing. A load of 0.5N is applied onto the shaft. The load is not continoous....May be once in 30 minutes. I am not in a favour of lubricating the shaft-bearing arrangement because of some environmental reasons.
Hence, I am confused while selecting the BEARING MATERIAL....
I know that Babbit, Bronze are such materials avaliable but the problem with that it doesn't have a WEAR RESISITANT Ability. These materials do wear easily.
Shall I use hard materials for SHAFT-BEARING ? I would select SHAFT of OHNS material (58-60HRC). But what should be the Bearing Material...Shall I use some hardened Steel in EN series like EN19 which will avoid wear of the shaft & bearing & will function properly for a long period of time.
Please let me know your comments.
Ash
Old 03-14-2011, 09:02 AM
Ash, There are wear resistant Bronze materials. Some have graphite or "Teflon" embedded in them. Many steel mill roll bearings are made of bearing bronze.
Try to "google" Rowend industries inc. Good info in their catalogue.
Also, there are many "plastic" bearings as well IGUS and SAINT-GOBAIN for example.
Dick Z
DZASTR
Old 03-15-2011, 10:38 PM
Ashish B's Avatar
Thanks for the reply....But why BRONZE material is favourable.
Why not use the shaft as well as bearing of a hardened steel (58HRC) ?
Old 03-16-2011, 02:42 AM
Ashish B's Avatar
Also,
Normally a Bearing is stationery & the shaft is rotating....We normally used hardened shaft & bronze bearings.
But if in my application, the shaft is stationery & the bearing is rotating....
So, shall I swap the material...In short, shall i used a hardened material for bearing (which is rotating) & bronze shaft (which is stationery).
Ash
Old 03-16-2011, 04:38 PM
An Aluminum Bronze bearing with Teflon type plugs or strips in them do not require additional lubrication. There are other bronze alloys that will work as well.
I'd use them in the moving part and have the shaft part made of highly polished hardened steel.
Dick Z
ADD: TRY www.rowend.com
DZASTR
Old 03-16-2011, 07:43 PM
Lucanus is on a distinguished road
You've all been trollled.
Ashish B = Zirok = Ramu.
Probably one of the biggest trolls on cnczone.com. Stay well clear lads, well clear.
Originally Posted by diylife.com.tw
If you have any assistance which we could serve to you, please do not contact us
Need Help!- Bearing or Oilite Bearing robe_uk DIY-CNC Router Table Machines 5 02-15-2011 08:24 AM
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 02:49 PM
high performance plastic - bearing material Chris D Glass, Plastic and Stone 6 09-03-2005 06:43 AM
Material ID DLMACHINE General Metal Working Machines 1 02-24-2004 07:58 AM
Bearing material pminmo DIY-CNC Router Table Machines 1 11-10-2003 06:18 PM
