Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 02-08-2011, 10:50 AM
engineerme is on a distinguished road
Dual Motor Axis?
Hi, im wondering if this idea is fesible, or, if it has already been accomplished how did it go?
Got belt driven axis, x and y. Failry long (500mm by 1000mm). Got Nema 17 motors (0.6amp) with a cnc controller which can control upto 3.5amp. Got t5 pulley’s with 16mm wide belt. Now then, it is possible if i use two motors wired in as one for one axis? i mean, put one motor at one end and one motor at the other end connected by a belt. would resistance in the wires have to be the same in order to get each coil inside each motor the same amount of power?
I am trying to increase accuracy, torque and overall cost as i have a few nema 17’s, i am aware that it would be easier to get a higher motor to achieve all this but i would like to mix it up a little. Has anybody tried using this set-up with a belt driven table?
Duncan
Old 02-11-2011, 03:24 PM
woohoo it works
Dual Steppers or Timing Belt for Dual X-axis? GEBrown Linear and Rotary Motion 3 05-27-2010 11:45 AM
Dual Z axis and Dual Spindle Adamj12b Mach Software (ArtSoft software) 3 08-28-2008 03:15 PM
Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. kreutz Stepper Motors and Drives 3 07-03-2008 06:57 PM
