Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 11-07-2010, 08:17 AM
Ashish B's Avatar
Ashish B is on a distinguished road
Post Force Screw Driver
I have to fix 2 screws (opposite to each other) in a housing. Between these 2screws a cylinder rotates. The cylinder will perform OKAY only when there is equal pressure from both sides (screws).
The problem to me how should i sense that equal pressure is given from both sides.
I wish that there would be some device avaliable in market which would illuminate light after a particular preset limit is reached.
Do anyone know about any such device in existence which would solve my problem.?
Responses will be really really thankful.
Old 11-15-2010, 04:12 PM
varium is on a distinguished road
If you google pressure sensors you'll find plenty of info to keep you busy for weeks. Thinking working this out should be fairly simple, and really easy if hydraulically actuated. Wish i could help out more, but without any info on the machine itself, or pics of its insides, its going to be impossible to suggest anything helpful.
Old 11-16-2010, 01:03 AM
Ashish B's Avatar
Wink
Hey,
I got to know that there are some Torque Screw Drivers in the market too. They sense the amount of torque to be applied & illuminates light when the torque is reached & avoid extra tightening of the screws.
Need Help!- Force toolchange ??? Lval EdgeCam 5 04-28-2008 02:33 AM
Need to know how much force in psi RedDog22 Mechanical Calculations/Engineering Design 17 01-05-2008 04:32 PM
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
Mechanics question - force at end of screw... Chris D Mechanical Calculations/Engineering Design 7 07-26-2005 07:09 AM
