Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Hobby Discussion
Hobby Discussion Discuss other CNC-related Hobbies here.
Old 09-12-2010, 08:32 AM
Deviant is on a distinguished road
Q: BeeHive Frame Assembly Automation Machine
I found a link to a machine on youtube that automatically assemblys hive frames.
YouTube - Brandt Automation Bee Hive Foundation Frame Assembler
Can anyone provide links or help on how one of these would run. What type of software and controls would be used?
I'm pretty sure that I can do each station seperately with existing cnc equipment or some of the pic/arm chips with feedback sensors.
But how is it done professionaly?
Old 09-20-2010, 12:05 AM
trevj1 is on a distinguished road
http://www.brandtautomation.com/case...d=6&item_id=21
The url was in the description on the vid.
In truth, that appears very much to be a process that could be set up quite well without software at all, simply using all mechanical or pneumatic functions to drive it, limiting electricity for use to run indicators for failure points, such as empty feeders, or the like, which would cause a stoppage.
Cheers
Trev
Machine Automation rrossey General Metal Working Machines 5 12-25-2009 10:31 AM
Assembly Table / Vacuum Frame Press ger21 WoodWorking 2 03-16-2009 10:07 AM
Chinese aluminium frame machine settle DIY-CNC Router Table Machines 3 07-08-2008 04:18 PM
DIY Face Frame Machine bigz1 WoodWorking 0 04-27-2007 05:37 PM
Machine Building Drives & Automation NEC audioandy1762 Trade Shows and Events 0 01-25-2007 06:55 AM
