Results 1 to 4 of 4
Thread: I need help finding someone to do some CNC work in New york area
    Apr 2010
    Hello,
    I wasn't sure where to post this so I hope this is a good enough place under the general tab. I am working with 1" thick, 1/2" thick and 1/4" thick acrylic sheet that I need to have cut with a proper CNC machiene. The project will be made up of rectilinear pieces and components that must fit together acuratly. I have drawn it on AotoCad as well so its all layed out and can provide whatever drawing a machenist needs to plug into thier CNC computer. I would also like to purchase the acrylic from the same place as well. looking for Polycast cast acrylic sheet for the 1" and 1/2", the 1/4" can be less expensive grade. 1" will be clear, 1/2" will be black and 1/4" will be a combo of red and clear.
    can you help me find a good CNC machienist in the NY area approx 1/2 hour north from NYC. I will also travel upto 1 hour from my westchester home. thanks so much for your help. also I will need about 50 or so pieces cut can you give me an idea how much I should be looking at for this type of project?
    Apr 2010
    any help would be appreciated greatly.
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Post
    Coralcrazed,
    You might have better luck posting in the RFQ section of the forum.
    http://www.cnczone.com/forums/employment_opportunity/
    You may receive better pricing if you allow others to bid that are not in your area, the goods could be shipped.
    Welcome to the Zone,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jul 2010
    re: need work
    I came across your post and I beleive i will be able to help you. I have a 4 axis cnc table of 4x8ft. This table will cut wood, plastic, foam, and sheets of rubber with a rotary cutter. If your interested in me helping you, send me more detail and dimensions of your needs. You can contact me via email.
    Willie D Richardson
    wrichardson@comsouth.net
  1. Need Advice on Finding Work Plus What Size Plasma Table to Build
    By Beefy in forum Australia, New Zealand Club house
    Last Post: 02-09-2010, 02:28 AM
  2. Finding Work plus Need Suggestions on Plasma Table Size
    By Beefy in forum General Metal Working Machines
    Last Post: 01-23-2010, 05:36 AM
  3. Finding work when your talent is a specialty service.
    By microfusion in forum Employment Opportunity
    Last Post: 09-18-2009, 07:30 PM
  4. WTB a CNC X/Y router 2' x 4' work area...
    By Robot Dude in forum Want To Buy...Need help!
    Last Post: 08-08-2008, 12:56 PM
  5. Looking for work in N.C. area
    By gv71 in forum Employment Opportunity
    Last Post: 01-22-2006, 10:30 PM
