Results 1 to 3 of 3
Thread: How to scan an object to scale?
    Aug 2008
    Hi
    First off I amtrying to create a create an acurate scan of a flexible keyboard and create a custom computer keyboard from it.
    Basically I am trying to create proper keys for the TAB, SPACE, ESC, ALT, CNTRL, (QWERTY KEYS).
    I want to SCAN the image in from a scanner and just draw boxes around it in Adobe Illustrator and have the CNC go cut the right sizes out, but when ever I try to scan I can never scan it to the proper scale of the actual item, its always huge and really high res ( i tried lowering it).
    How can I scan a image to scale (scale meaning the size of it in reallife). A 0.5x0.5 " key would scan to like 3"x3"
    Apr 2010
    korea
    I do something like this quite often too..(model cars)
    What I do is I use multiple sources like scanner, camera and most usefully, contour gauge.
    But something like a key board button, I'd just measure it.
    and another thing... I believe it scans 1:1 anyways.. on AI(and Photoshop) it just look bigger 'cause of the high resoultion.
    have u try printing the scanned image? does it still print big?
    Registered dustin1706's Avatar
    Apr 2009
    canada
    I don't use illustrator myself, but If your key is .5^2 and your pic comes out to 3^2. just select the image and reduce its size to .1666667% Leave the resolution high.
    I am assuming that you are printing the scanned image at 100% before measuring and not measuring on your monitor?
    As long as the dimensions are right you should be able to scale it in adobe, or in your cad/cam software. It would probably be easier to draw the boxes accurately at the bigger size anyway?
    JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router
    Joes 4x4 R&P in progress
  1. Need to make scale tire mold for 1/6 scale car
    By thuffner3 in forum Moldmaking
    Last Post: 04-29-2008, 01:57 AM
  2. Need 2D or 3D object Digitized Who can help
    By mattsam in forum Employment Opportunity
    Last Post: 03-15-2008, 08:18 AM
  3. Can,t fill my object
    By ZipSnipe in forum TurboCAD/CAM
    Last Post: 02-27-2006, 09:07 PM
  4. CAD HELP: 4 lines to 1 box/object how to?
    By FireFghtr in forum General CAM Discussion
    Last Post: 02-24-2006, 04:03 PM
  5. 3d Object Digitizing
    By DAB_Design in forum Employment Opportunity
    Last Post: 06-20-2005, 12:55 AM
