Wiring a simple air compressor
Results 1 to 1 of 1
Thread: Wiring a simple air compressor
    Antip's Avatar
    Sep 2017
    Milan
    Default Wiring a simple air compressor
    An air compressor with model: IV5076055 (From Industrial air USA) is at up front. I can't find information about HP on the manual for wiring purpose. The data at disposal is:
    60 gallon Vertical
    175 Max PSI
    15.3 CFM @ 100 PSI
    13.5 CFM @ 175 PSI
    5.0 RHP
    Any help/suggestions on wiring?
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Wiring a simple air compressor
    Quote Originally Posted by Antip View Post
    5.0 RHP
    I would use a 4mm (diameter) wire and a 32A breaker.
    Dec 2003
    The link says 5HP, the manual does not give any details on wiring connections except 230v and 'refer to the motor plate'!
    What exact info are you looking for?
    Jan 2018
    Viet Nam
    I usually use strings 6mm
