Need Help! Basic Wooden Cube
Results 1 to 8 of 8
Thread: Basic Wooden Cube
    Jun 2016
    Default Basic Wooden Cube
    Hi all,
    I'm extremely new to wood working and the CNC community and I wanted a project that will keep me busy. I recently ordered 1-inch wooden cubes. However, they are not exact. So if I stack them 10-inches high, there are slits that let light through. I wanted to have them EXACTLY 1-inch and I was hoping a CNC machine would help me. I'm not new to hard work and research but I feel a quick post may save me a week or so as I only get how to create a turner cube. All I need to know is what kind of machine will work and is there a suggested DIY build?
    Mar 2013
    Default Re: Basic Wooden Cube
    I think a good table saw and planer is probably a better approach than a cnc for this particular job.
    Jun 2016
    That's what I originally wanted to try but I'm having trouble thinking of a way to hold down 100 blocks. I've created a kind of 'holder' but it doesn't work very good. Maybe I'll research a better way to hold the blocks. Thank you for your reply
    Also, hypothetically, if I were to use a CNC machine, which would be advised?
    Mar 2013
    Quote Originally Posted by foxberg View Post
    I'm not sure what you mean by a holder. You don't need to hold down 100 blocks to make them. Use the planer and table saw to make 1 inch thick, 1 inch wide strips of wood of any length (lets say 3 feet). Then just cut off 1 inch pieces from the end by setting the table saw fence (so you don't have to repeatedly measure). You can use a cross-cut sled for this last part.
    As far as what cnc to get...that is a whole can of worms and there are thousands of posts on this site for you to look through that show everything from diy scratch builds to full fledged machining centers.
    Jun 2016
    Quote Originally Posted by manofmanyhats View Post
    ohhhh, I see. Okay that makes more sense. Sorry for the noob question and thank you for your help
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Do not cut 1" cubes between the fence and blade. You need to use a cutoff sled with a stop block.
    UCCNC 2017 Screenset
  7. #7
    Jun 2016
    Quote Originally Posted by ger21 View Post
    oh ok. I didn't think of that but that makes sense. Thank you
  8. #8
    Nov 2008
    Woodworking involves planning. Rip cut two sides to 1" by the length of the wood then use a miter fence with a stop block to cut the remaining faces.
    Or safer yet put a mark on the tabletop and cut 1" length to that mark.
Basic Wooden Cube
Basic Wooden Cube
