Hitachi Seiki HT20 SII - not enough memory for program
Results 1 to 3 of 3
Thread: Hitachi Seiki HT20 SII - not enough memory for program
    May 2010
    PL
    Default Hitachi Seiki HT20 SII - not enough memory for program
    Hello,
    I've got Hitachi Seiki HT20 SII CNC turning machine. Today I've tried to send some programs to memory via RS232. All works ok, so I cleared all the memory and tried to send longer program, about 560 lines (generated with CAM). And there is a problem, the memory is not enough for this program. It's a big problem for me, because I often turn complicated combinations of radius, and using CAM is only option. Moreover, I think 560 lines is not a long program, sometimes I use few thousands lines.
    So the question is - is it possible to extend the memory? Or use some external?
    Please help me
    Mar 2011
    uk
    Default Re: Hitachi Seiki HT20 SII - not enough memory for program
    Hi, I have same problem did you sorted out ?
    Member shas595's Avatar
    Dec 2009
    Hello
    it is possible, send me a PM with you email and I will assist
    John
    PAVEL_vk45II's Avatar
    Jan 2022
    ????????????. ? ???? ?? ?? ???????? ? ???????. ?? ?? ???????. ?????? Hitachi seiki vk45II. ??????? ?????? ?
